Overview
This library provides vernacular files containing tactics for simplifying the proofs of inequalities on expressions of real numbers for the Coq proof assistant.
This package is free software; you can redistribute it and/or
modify it under the terms of CeCILL-C Free Software License (see
the COPYING
file in the archive).
This library is hosted on the Inria Gitlab server. It is mainly developed by Guillaume Melquiond. Automatically generated documentation of the vernacular files is available here.
Building and Installing using OPAM
If you are managing your Coq installation using Opam, you can install the library using the following command:
opam install --jobs=2 coq-interval
Note that the coq-interval
package is hosted in the Opam
repository dedicated
to Coq libraries.
So you have to type the following command beforehand, if your Opam
installation does not yet know about this repository.
opam repo add coq-released https://coq.inria.fr/opam/released
Building and Installing from Sources
Source tarballs
The following is a selection of some releases of the library, depending on the version of Coq. Minimal versions required for the dependencies are also indicated.
- version 4.10.0 (Coq 8.11 to 8.19, Flocq 3.2, MathComp 1.9, Coquelicot 3.1),
- version 4.6.1 (Coq 8.8 to 8.17, Flocq 3.1, MathComp 1.7, Coquelicot 3.0),
- version 3.4.2 (Coq 8.7 to 8.11, Flocq 3.0, MathComp 1.6, Coquelicot 3.0),
- version 3.3.0 (Coq 8.5 to 8.8, Flocq 2.5, MathComp 1.6, Coquelicot 3.0),
- version 3.1.1 (Coq 8.5 & 8.6, Flocq 2.5, MathComp 1.6, Coquelicot),
- version 2.2.1 (Coq 8.4 & 8.5, Flocq 2.5, MathComp 1.6, Coquelicot).
Other releases can be found here.
Dependencies
In addition to the Coq proof assistant, you need the following libraries:
- Mathematical Components,
- Flocq,
- Coquelicot,
- BigNums (for Coq >= 8.7).
Configuring, compiling, and installing
Ideally, you should just have to type:
./configure && ./remake --jobs=2 && ./remake install
The environment variable COQC
can be passed to the
configure script in order to set the Coq compiler command. The configure
script defaults to coqc
. Similarly, COQDEP
can
be used to specify the location of coqdep
. The
COQBIN
environment variable can be used to set both
variables at once.
The library files are compiled at the logical location
Interval
. The COQUSERCONTRIB
environment
variable can be used to override the physical location where
the Interval
directory containing these files will be
installed by ./remake install
. By default, the target
directory is `$COQC -where`/user-contrib
Invocation
In order to use the tactics of the library, one has to import the
Interval.Tactic
file into a Coq proof script. The main
tactic is named interval
The tactic can be applied on a goal of the form c1 <= e
<= c2
with e
an expression involving
real-valued operators. Sub-expressions that are not recognized by the
tactic should be either terms t
appearing in hypothesis
inequalities c3 <= t <= c4
or simple integers. The
bounds c1
, c2
, etc, are expressions that contain
only constant leaves, e.g., 5 / sqrt (1 + PI)
The complete list of recognized goals is as follows:
c1 <= e <= c2
;e <= c1
,c1 <= e
,e >= c1
, andc1 >= e
;e < c1
,c1 < e
,e > c1
, andc1 > e
;e <> c1
andc1 <> e
;Rabs e <= c1
, handled as-c1 <= e <= c1
The complete list of recognized hypotheses is as follows:
c1 <= t <= c2
,c1 <= t < c2
,c1 < t <= c2
,c1 < t < c2
;t <= c1
,c1 <= t
,t >= c1
, andc1 >= t
;t < c1
,c1 < t
,t > c1
, andc1 > t
;Rabs t <= c1
andRabs t < c1
The tactics recognize the following operators: PI
, Ropp
Rabs
, Rinv
, Rsqr
, sqrt
cos
, sin
, tan
, atan
exp
, ln
, pow
, Rpower
, powerRZ
Rplus
, Rminus
, Rmult
, Rdiv
Flocq's operators Zfloor
, Zceil
, Ztrunc
ZnearestE
(composed with IZR
) are also
recognized. Flocq's operator Generic_fmt.round
with format
FLT_exp
is also supported.
There are some restrictions on the domain of a few
functions: pow
and powerRZ
should be written
with a numeric exponent; the input of cos
and sin
should be between -2*PI
and 2*PI
; the input of tan
should be between
-PI/2
and PI/2
. Outside of these domains, the
trigonometric functions return tight results only for singleton
input intervals.
A helper tactic interval_intro e
is also available. Instead
of proving the current goal, it computes an enclosure of the expression
e
passed as argument and it introduces the resulting
inequalities into the proof context. If only one bound is needed, the
keywords lower
and upper
tactic, so that it does not perform useless computations. For
example, interval_intro e lower
introduces only the
inequality corresponding to the lower bound of e
in the
context. The interval_intro
tactic uses a fresh name for the
generated inequalities, unless one uses as
followed by an
intro pattern.
The integral
tactic is a specialized version
of interval
that can be used when the target enclosure
involves an expression containing an integral. Such an integral should be expressed
using RInt
; its bounds should be constant; and its integrand
should be an expression containing only constant leaves except for the
integration variable. Improper integrals are also supported, when
expressed using RInt_gen
. The supported bounds are
then (at_right 0) (at_point _)
and (at_point _)
(Rbar_locally p_infty)
. In the improper case, the integrand should
be of the form (fun t => f t * g t)
with f
a function bounded on the integration domain and g t
one of
the following expressions:
(ln t) ^ _
,powerRZ t _ * (ln t) ^ _
,/ (t * (ln t) ^ _)
The root H
of interval
involves an expression that is constrained by an equation whose proof
is H
. Rather than an equality proof, the tactic can also
be passed an equality statement or even just a real expression (then
assumed to be zero), in which case the tactic generates a new goal
that asks for a proof of this equality.
The helper tactic integral_intro
is the counterpart
of interval_intro
, but for introducing enclosures of
integrals into the proof context. As with interval_intro
keywords lower
, upper
, and as
, are
supported. Similarly, root_intro
introduces enclosures of roots into
the proof context. Only as
is supported in that case. When an
equality (rather than a proof) is passed to root_intro
, no new goal
is generated, but the introduced hypothesis uses the equality as its
antecedent.
Tactics interval_intro
, integral_intro
and root_intro
are available as degenerate forms that
unify the obtained enclosure with the current goal. They are meant to
be used when the goal is an existential variable, e.g., in a
tactic-in-term context. Those degenerate forms are
named interval
, integral
and root
, for conciseness, but they should not be
confused with the original tactics. For all intents and purposes, they
behave like the *_intro
tactics.
Both interval_intro
and integral_intro
forms that unify the obtained enclosure with the current goal. They
are meant to be used when the goal is an existential variable, e.g.,
in a tactic-in-term context. Those degenerate forms are named
interval
and integral
they should not be confused with the original tactics. For all intents
and purposes, they behave like interval_intro
and integral_intro
The plot
tactic produces correct function graphs, that
is, two curves that are guaranteed to enclose the given function on the
given input interval. It is invoked as plot f x1 x2
. An
output range can optionally be passed: plot f x1 x2 y1 y2
If not, it is computed on the fly.
The Interval.Plot
file provides a Plot
command that can be used to display a function graph. This is done by
invoking the gnuplot
command, which thus needs to be
installed. If a string is passed as an optional argument, instead of
invoking gnuplot
, a file is created with the corresponding
Gnuplot script.
Fine-tuning
The behavior of the tactics can be tuned by passing an optional set of
parameters with (param1, param2, ...)
. These parameters are
parsed from left to right. If some parameters are conflicting, the
earlier ones are discarded. Available parameters are as follows (with the
type of their arguments, if any):
i_prec (p:positive)
- Set the precision used to emulate floating-point computations. If
this parameter is not specified, the tactics perform computations
using machine floating-point numbers, when available. Otherwise, the
tactic defaults to using
i_prec 53
. Note that, in some corner cases, the tactics might fail when using native numbers, despite the goals being provable using a 53-bit emulation. i_native_compute
- Perform computations using
native_compute
instead ofvm_compute
. This greatly increases the startup time of the tactics, but makes the computations faster. This is useful only for computationally-intensive proofs. i_bisect (x:R)
- Instruct the tactics to split the interval enclosing
x
until the goal is proved on all the sub-intervals. Severali_bisect
parameters can be given. In that case, the tactic cycles through all of them, splitting the input domain along the corresponding variable. Computation time is more or less proportional to the final number of sub-domains. This parameter is only meaningful for theinterval
andinterval_intro
tactics. i_depth (n:nat)
- Set the maximal bisection depth. Setting it to a nonzero value has
no effect unless
i_bisect
parameters are also passed. If the maximal depth isn
, the tactic will consider up to 2n sub-domains in the worst case. As withi_bisect
, this parameter is only meaningful for theinterval
andinterval_intro
tactics. The maximal depth defaults to15
forinterval
, and to5
forinterval_intro
. Note thatinterval_intro
computes the best enclosure that could be verified byinterval
using the same maximal depth. i_autodiff (x:R)
- Instruct the tactics to perform an automatic differentiation of the
target expression with respect to
x
. This makes the tactic about twice slower on each sub-domain. But it makes it possible to detect some monotony properties of the target expression, thus reducing the amount of sub-domains that need to be considered. Note that this is only useful if there are several occurrences ofx
in the goal. This parameter is only meaningful for theinterval
andinterval_intro
tactics. It is mutually exclusive withi_taylor
. This parameter can also be used with theroot
androot_intro
tactics, if they did not guess the correct target variable. i_taylor (x:R)
- Instruct the tactics to compute a reliable polynomial enclosure of
the target expression using Taylor models in
x
. As withi_autodiff
, this is useful only ifx
occurs several times in the goal. Computing polynomial enclosures is much slower than automatic differentiation, but it can reduce the final number of sub-domains even further, thus speeding up proofs. Note that it might fail to prove goals that are feasible using automatic differentiation. As withi_autodiff
, thei_taylor
andinterval_intro
tactics. It is implicit for theintegral
,integral_intro
, andplot
tactics, as Taylor models of the integrand (respectively, plotted function) are computed with respect to its variable. i_degree (d:nat)
- Set the degree of polynomials used as enclosures. The default degree
is 10. For
interval
andinterval_intro
, this parameter is only meaningful in conjunction withi_taylor
. i_fuel (n:positive)
- Set the maximum number of sub-domains considered when bounding
integrals. The tactics maintain a set of integration sub-domains; it
splits the sub-domains that contribute the most to the inaccuracy of
the integral until its enclosure is tight enough to satisfy the goal.
By default, the tactics will split the integration domain into at
most 100 sub-domains. This parameter is only meaningful for
the
integral
andintegral_intro
tactics. i_width (p:Z)
- Instruct the
integral_intro
tactic to compute an enclosure of the integral that is no larger than 2p. The tactic will split the integration domain until the resulting enclosure reaches this width ori_fuel
is exhausted. This parameter is meaningless for the other tactics. It is mutually exclusive withi_relwidth
. i_relwidth (p:positive)
- Instruct the
integral_intro
tactic to compute an enclosure of the integral whose relative width is no larger than 2-p. This parameter is meaningless for the other tactics. It defaults to 10. This means that, if neitheri_width
nori_relwidth
is used,integral_intro
will compute an enclosure of the integral accurate to three decimal digits, assumingi_fuel
is large enough. i_size (w h:positive)
- Instruct the
plot
tactic to target a resolution ofw
byh
pixels. This parameter is meaningless for the other tactics. It defaults to a resolution of512x384
. The tactic will subdivide the input interval intow
subintervals, and it will try to ensure that the function graph is no larger than a few pixels vertically. i_delay
- Prevent Coq from verifying the generated proof at invocation time.
Instead, Coq will check the proof term at
Qed
time. This makes the tacticsinterval
,integral
, androot
instant. But it also means that failures, if any, will only be detected atQed
time, possibly with an inscrutable error message. This parameter is thus meant to be used when editing a proof script for which the tactics are already known to succeed. For the tacticsinterval_intro
,integral_intro
, androot_intro
, computations are performed anyway (the risk of failure is thus negligible), but thei_delay
parameter postpones their verification untilQed
time. This makes these tactics twice as fast and is especially useful when optimizing the arguments ofi_prec
,i_degree
, etc. For the degenerate forms ofinterval_intro
,integral_intro
, androot_intro
, thei_delay
parameter is always passed implicitly. i_decimal
- Instruct the tactics to output interval bounds using a decimal
representation. This parameter is only meaningful for the tactics
interval_intro
,integral_intro
, androot_intro
, as well as the corresponding degenerate tactics.
Examples
From Coq Require Import Reals Lra. From Interval Require Import Tactic. Open Scope R_scope. Notation "x = y ± z" := (Rle (Rabs (x - y)) z) (at level 70, y at next level). (* Tactic interval *) Goal forall x, -1 <= x <= 1 -> sqrt (1 - x) <= 3/2. Proof. intros. interval. Qed. Goal forall x, -1 <= x <= 1 -> sqrt (1 - x) <= 141422/100000. Proof. intros. interval. Qed. Goal forall x, -1 <= x <= 1 -> sqrt (1 - x) <= 141422/100000. Proof. intros. interval_intro (sqrt (1 - x)) upper as H'. apply Rle_trans with (1 := H'). lra. Qed. Goal forall x, 3/2 <= x <= 2 -> forall y, 1 <= y <= 33/32 -> sqrt(1 + x/sqrt(x+y)) = 144/1000*x + 118/100 ± 71/32768. Proof. intros. interval with (i_prec 19, i_bisect x). Qed. Goal forall x, 1/2 <= x <= 2 -> sqrt x = ((((122 / 7397 * x + (-1733) / 13547) * x + 529 / 1274) * x + (-767) / 999) * x + 407 / 334) * x + 227 / 925 ± 5/65536. Proof. intros. interval with (i_bisect x, i_taylor x, i_degree 3). Qed. Goal forall x, -1 <= x -> x < 1 + powerRZ x 3. Proof. intros. apply Rminus_lt. interval with (i_bisect x, i_autodiff x). Qed. From Flocq Require Import Core. Notation round := (round radix2 (FLT_exp (-1074) 53) ZnearestE). Goal forall x, -1 <= x <= 1 -> rnd (1 + rnd (x * rnd (1 + rnd (x * (922446257493983/2251799813685248))))) = exp x ± 31/100. Proof. intros. interval with (i_taylor x). Qed. (* Tactic integral *) From Coquelicot Require Import Coquelicot. Goal RInt (fun x => atan (sqrt (x*x + 2)) / (sqrt (x*x + 2) * (x*x + 1))) 0 1 = 5/96*PI*PI ± 1/1000. Proof. integral with (i_fuel 2, i_degree 5). Qed. Goal RInt_gen (fun x => 1 * (powerRZ x 3 * ln x^2)) (at_right 0) (at_point 1) = 1/32. Proof. refine ((fun H => Rle_antisym _ _ (proj2 H) (proj1 H)) _). integral with (i_prec 10). Qed. (* Tactic root *) Goal forall x:R, 999 <= x <= 1000 -> sin x = 0 -> x = 318 * PI ± 1/1000. Proof. intros x Hx Hs. root Hs. Qed. (* Degenerate forms *) Definition equal_1 x `(0 <= x <= PI/2) := ltac:(interval ((cos x)² + (sin x)²) with (i_taylor x)). Definition equal_PI_over_4 := ltac:(integral (RInt (fun x => 1 / (1+x*x)) 0 1)). Definition equal_0_442854401002 x := ltac:(root (exp x = 2 - x) with i_decimal). (* Tactic plot and command Plot *) From Interval Require Import Plot. Definition p1 := ltac:(plot (fun x => x^2 * sin (x^2)) (-4) 4). Plot p1. Definition p2 := ltac:( plot (fun x => sin (x + exp x)) 0 6 (-5/4) (5/4) with (i_size 120 90, i_degree 6)). Plot p2 as "picture.gnuplot". Plot ltac:(plot (fun x => sqrt (1 - x^2) * sin (x * 200)) (-1) 1 with (i_degree 1, i_size 100 300)).
